  1. I just converted Divx to Avi If I burn it to VCD will it be able to view on My dvd player. my Apex is compatible with all CD-r VCD's. But I was told Avi files can only be viewed on a PC>
    I wanna slap you just for breathing!!!!!
    Feb 2001
    Berlin, Germany
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Not a good starting point....
    btw, convert to MPEG before burn to VCD.
  3. Take a look to the left under 'Convert' you'll find info there on converting a DiVX file to a VCD. There are also guides at http://www.doom9.org and http://www.flexion.org/vcd
    There's no reason to convert the DivX to an AVI first (well normally no good reason ) The APEX will play just about anything you put in it so your ok at that end.
