I used nero and burnt the cd as an image. The movie burned ok, but i cant get the movie to play on my computer. I have only used .bin and .cue with games, so i dont know how to use them with movies. Can some one please help me.
Use a software DVD player to try to play it.
Panasonic DMR-ES45VS, keep those discs a burnin' -
Try using VCDgear to convert the CUE\BIN to an MPEG
It may just be an image of an MPEG and not of a VCD\SVCD
Then burn with VCDeasy
I know the mpeg should play ok on your comp even if its not (S)VCD, But i had this problem once when trying to convert mpeg images with Isobuster (Same as coverting to disk but puts it on your hardrive)
Plus nero is not that good at burning BIN & Cue files you could also try CDRwin for burning the image (Much Better)
Opening Or Playing a .Bin Format Video?
By niteghost in forum Video ConversionReplies: 12Last Post: 6th Oct 2008, 07:42 -
For AVG users (missing bin file)
By stiltman in forum ComputerReplies: 6Last Post: 17th Aug 2008, 23:16 -
Opening .bin file jpg
By chewie8008 in forum ComputerReplies: 4Last Post: 18th Jul 2007, 16:01 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 13:05 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 07:44
