Specifically, I want to be able to use VobSub in AviSynth. I like how VobSub works with Virtualdub frameserved to CCE. However, my encoding speed decreases to about 0.8 using Virtualdub vs. the 1.3 using AViSynth to CCE. So is there a way to make VobSub work in AviSynth?
Or is there any other way to make subtitles using AviSynth?
Thanks all!
This is from the AVIsynth side:
Avisynth 1.0 beta supports VirtualDub plugin filters.
VirtualDub plugin filters are supported, via the LoadVirtualdubPlugin command. Convenient Avisynth-style interfaces to many VirtualDub plugins are available in the file vdfilters.avs, which is included with the DLL above
There's also an AVIsynth subtitler at dvd2svcd.doom9.net that you can use. No really good directions, but basically run subrip and create bmps of all the subtitles and a subtitle.txt/persubs.txt file with the timing info. Then load the AVIsynth subtitler filter and ref the subtitles.txt file for timing info.
This is the default subtitle optition for DVD2SVCD.
Is there a way to use avisynth plugins/filters within Virtualdub?
By Milardo in forum EditingReplies: 5Last Post: 5th Jan 2011, 03:52 -
VirtualDub Plugins
By gazza67 in forum Newbie / General discussionsReplies: 6Last Post: 12th Dec 2009, 08:50 -
programm which can make frameserving for Avisynth script
By Yury Perschin in forum Capturing and VCRReplies: 0Last Post: 20th Jan 2009, 11:19 -
Basic question about AVISynth plugins
By sd_smoker in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2008, 11:04 -
How to install plugins for Avisynth?
By 1gnition in forum Capturing and VCRReplies: 4Last Post: 19th May 2007, 19:06
