I want to transfer my mp3s to DVD, if i do is there any way to display a picture whilst they are playing on the DVD player itself?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
mp3's on DVD is (to the exception of 1 or 2?) supported by no players. There are some workarounds, but it seems that even that way, you fit less mp3's per DVD than on a normal CDR. Try a forum search.
Ok, even on a CDr then , is there any way to show pics while playing mp3s. Is there any way to put a menu on the disc to select which mp3?
Sonic DVDit! PE will allow you to display a pic while it plays an audio track. The program will transcode the audio to AC3.
you will probably find the process a bit tedious especially if you want to do it with hundreds of audio files. -
Ok, I read your question wrong in the first place and didn't see the "picture" part of it. I thought you only wanted mp3's on a DVD. You can make a (S)VCD or DVD with whatever sound track you want, mind you, I've never tried before as I have no need for it...
I should have said that DVDit! PE will transcode an 'acceptable' audio format into AC3. MP3 is not an acceptable format so you will have to convert them to WAV first, making the whole process even that much more tedious.
Burrrn and MP3s
By Fantome in forum AudioReplies: 7Last Post: 16th Dec 2010, 10:25 -
Creating a DVD using VOBS & MP3s
By ZenFrog76 in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2009, 03:00 -
Can't play MP3s on my Sony DVP NS355 DVD player
By harrylentil in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Aug 2009, 14:04 -
mp3s to a dvd
By AeR0 in forum AudioReplies: 8Last Post: 2nd Aug 2008, 16:48 -
What software should I use to extract DVD audio and convert it to mp3s?
By maccaneer in forum MacReplies: 2Last Post: 4th Sep 2007, 18:03
