I'm new to this, bear with me please. I have a Dual PIII 800 with lots o' drive space, optionally have an Athlon 1600 available. I own a WinTV-D, a Osprey-100, a Winnov PCI and an old Miro DC20. I have a handful of SBLive! cards if needed.
I want to capture Formula One races this season from my dish service, save them on hard disk, and burn them onto my Sony DRU-500a. I have money to get a ~$300 USD capture card, not sure what to get. One I've looked most closely at is the Hauppauge pvr-350.
Should I be capturing directly into MPEG2 for this? I'll also want to edit out commercials, etc. Any help is greatly appreciated. Wish I had last season's races, which is why I want to be prepared for this year esp. since we're getting the Bernie-vision feed in the USA now.
thx
Hi,
I think that the WinTV-D will let you capture tv into mpeg2 files.
Regards,Jose Febus -
I have an ATI All-in-Wonder Radeon with a 800MHZ computer and can capture DVD compliant MPEG-2 at 352X480, 6000kbps without any frame drops. You can purchase a new ATI AIW 7500 for about $135.
I do alot of caps from DirecTV and recommend using a digital camcorder with analog pass-through to convert the TV signal to DV and then bring it into your computer via Firewire. I use a Dazzle Hollywood DV-Bridge to perform the analogTV-to-DV conversion to save my camcorder. ADS Tech and Canopus also make analog2DV units. I haven't tried the ADS or Canopus units and must say that the Dazzle unit occasionally disappears from my system.
Turns out I purchased a Canopus ADVC-100, I use that to capture via firewire into Premiere 6.5. Too bad VirtualDub doesn't seem to do 1394.
I cap it all as .avi, then I edit out commercials and export to MPEG and burn to DVD. The ADVC-100 does a fantastic job of straight MPEG capture, can't crow about it enough, but I like to be able to edit so .avi is my best path to happiness.
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 21:16 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
