I would like to edit some 8mm and VHS video which was captured to AVI-Huffyuv format to clean it up and remove noise before burning it to SVCD. However, I 'm having no luck using VirtualDub. When i apply the filters (deinterlace, temporal smoother) and save it back to AVI-Huffyuv format, the resultant video and audio begin to hang up and freeze. Is there another program which is as good as or better than VirtualDub when it comes to cleaning up, removing noise, etc for AVI files? My operating system is Windows XP. Capture software is iuVCR.
Avisynth is your answer. If you don't know what it is this site will help. Just one word about avisynth--> READ!!!
"The software said Win XP or better, so I Installed Linux"
Need Alternative To Roxio
By mlb32704 in forum Newbie / General discussionsReplies: 23Last Post: 9th Apr 2011, 18:50 -
FixVTS alternative
By hardy in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2010, 03:05 -
TeraCopy Alternative
By hardy in forum ComputerReplies: 20Last Post: 17th Aug 2009, 03:10 -
VirtualDub "Access Violation" Crash, Alternative Program?
By Ruro Jiruries in forum EditingReplies: 6Last Post: 29th Jul 2008, 16:16 -
Encoder Alternative
By ironape2 in forum Video ConversionReplies: 6Last Post: 16th May 2007, 16:31
