I have arcsoft showbiz software and mydvd. My first dvd that i burned was not the same quality as the dv. For instance, the video quality is much better when i play straight from the dig vid camera to the tv than the dvd that i made. Any suggestions will be greatly appreciated. Also have pinnacle software-how do i save movie so i can burn with this software? Also, when i download DLA it crashes my computer when i plug in my dv camera.
Capture the dv with for example scenalyzer live, convert to dvd with tmpgenc(very good quality) and author with ulead moviefactory, workshop or spruceup(they do not convert the audio to pcm and supports dvd compliants mpegs). It will also work to capture,convert and author to dvd with ulead moviefactory,workshop but you will not get the same quality as using tmpgenc...but it will be much more easier.
http://scenalyzer.com/main.html
http://www.vcdhelp.com/tmpgencdvd.htm
http://pwp.netcabo.pt/0165394101/TMPGEnc_Template.html
http://www.vcdhelp.com/author#dvd
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 04:52 -
simple question for experienced DVD player owners
By asmodeus718 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2010, 22:02 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10
