  1. HI i wonder if you can help me. WHen i burn svcd mpegs via bin/cue files or mpeg files some play perfectly well on my standalone dvd player
    on some the sound jumps (but this is rectified by slightly rewinding the disc
    and others the dvd kicks in pcb shows on the screen then play but then stop shows up on the screen (these do play on my pc via powerdvd)
    so why is this im in the uk (pal)
    The discs that dont play at all but on the pc are the most frustrating
    so why do these discs burn correctly but then dont on my dvd player
    Aug 2002
    MiddleShire UK
    Are you using the new version of nero ? i had the exact same thing where the PBC would show and play but nothing happened
    I went back to the older version and all was ok
    Mar 2001
    Antwerp - Belgium (Europe
    Use VCDwizard instead, you can generate a cd-image for the application you prefer : cdrdao or nero.
    Generated Nero-images can then be burned in each Nero version starting from rel. 5 and up.
    Nero just burns the images and won't change the contents of it.
