  1. I am having a problem with my bin files, well cue and bin, when ever I try to load them into vcdgear, I get the error (Binary image file specified inside cue file could not be opened), please could someone help, its really giving me a headache, I'm trying to burn my first dvd rip......
    Nov 2001
    Chihuahua, Mexico
    The file Path inside the cue file is wrong just correct it using notepad.
    ! Viva Mexico !
  3. Correct it to what path, how will I know what is wrong in there, thanx in advance for any help.....
  4. If the path says "C:\blah\blah\yourfile.bin"
    change it to
    "yourfile.bin"
    Then it should find it
    Otherwise you might have a corrupt bin & you are out of luck
    Panasonic DMR-ES45VS, keep those discs a burnin'
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If it says like "c:\bins\xyz\image.bin" somehere in the cue, and your bin is actually "C:\download\image.bin" it wont work. Change to just "image.bin" and everything will be fine as long as the cue and bin are in the same dir.
    /Mats
