I have a svcd of a movie, in svcd sound is perfect no sync problems at all.
the movie is broken down to 4 cd's. I was converting them to dvd using TMPGEnc. The 1st cd audio is out of sync i think about 8 sec before the video after converting to dvd, perfectly fine in svcd format. The other 3 cd's converted to dvd with no problems at all.
Any idea's on how to avoid this or you just the 1st part of a 4 part movie would be out of sync after converting to dvd?
If the original SVCD movie .mpg has glitches you need to remove them, or they will cause problems later. These problems would not be seen on playback.
Its much easier to fix problems with AVI than Mpeg 2
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
audio lagging off sync problem
By lindylex in forum Video ConversionReplies: 1Last Post: 4th Jul 2008, 19:01 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
