Hi im trying to covert a movie i downloaded to vcd. Im trying to rip the sound to wav with virtyaldub as i usually do but every time i try to save the wav an erroe message appears saying "The requested audio compression is not compatible with the input format. Check the sampling rate and channel count of the input match those of the requested format". I have no idea what this means could somone please tell me what to do. Thanks
Results 1 to 12 of 12
AUDIO -> CONVERSION -> 44100 Hz -> K -> SAVE AS AVI
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
this tends to happen if your d/l movie has a dolby digital track. virtual dub can't decompress. you can tell by checking file info. under audio it will show unknown tag 2000
you can always decompress by stripping the audio (direct stream copy) and change from wav to ac3 (change to all files) and then run in besweet.exe to produce your wav file. -
alternatively use TMPG to rip out wave. Load movie into TMPG, go to file - output to file - WAVE file. Had to do this recently myself with one film when virtualdub gave me exactly that message
you know it's the anti-Midas touch when all you touch goes to shit.............. -
Thanks for thhe suggestions i will try them all out, and post what worked best
Vdub works perfect with AC3...
Provided you have the little helper's
http://www.moonlight.co.il/download.htm
Moonlight Odio Dekoda DirectShow® filter, binary (71,855 bytes, ZIP)
Universal AC-3/MPEG Audio (Layer 1/2/3) Decoder
HTTP Download, U.S. Primary (it is recasting) need password
HTTP Download, U.S. Secondary
HTTP Download, Russia -
I can't seem to locate Universal AC-3/MPEG Audio (Layer 1/2/3) Decoder on the site.
The description says
Still some people cannot get Vdub to convert AC3, it might be something to do with all those dam codec packs
Maybe vdub AC3, or Vdub Mod will help those who cannot get it to work -
Think i've found that file but how do i install it....get 4 unpacked files....double clicked the reg file and get some dll message????
Some dll message ?Originally Posted by Celso
reg.bat This will register mlcom.ax
mlcom.ax
regsvr32.exe
unreg.bat
ReadMe.txt
Audio Encoding Help needed for VirualDub
By Qasim in forum AudioReplies: 8Last Post: 30th Apr 2010, 09:02 -
Question about the virualDub versions
By TheLost in forum Newbie / General discussionsReplies: 6Last Post: 16th May 2008, 21:54 -
VirualDub ERROR "VBR detected"???
By UmmAddan in forum Video ConversionReplies: 10Last Post: 4th Jun 2007, 16:27
