Results 1 to 9 of 9
  1. ok i had a movie encoded with divx
    but i want to put them on a dvd so i had to cut some parts a bit so they would fit
    now i used virtualdub to do this which worked but when the file was saved it didnt have a extension like the original avi
    anybody has an idea what causes this or how to fix this
  2. Member vhelp's Avatar
    Mar 2001
    New York
    morning Ace2,
    Do you mean, mydivXclip.AVI ??
    If there is no .AVI at the end, then just put one in.
    ..or something else ??
    -vhelp
  3. ya exactly no avi extension
    but if i just add one
    wouldnt this cause problems for some programs ?
  4. Member vhelp's Avatar
    Mar 2001
    New York
    ace2,
    sounds like all you did was cut the divX clip. It's still a divX clp (or AVI)
    But, w/out the .AVI extention name after the clip, some apps might not
    see it, and wont open it. That is, if you pratice this on-going.
    In the future, when you cut a divX clip (or any source) remember to see
    if the EXTension follows it. If it doesn't, and you catch this, just add the
    "correct" extension to using explorer or something.
    -vhelp
  5. ok thx alot for the help
  6. Member vhelp's Avatar
    Mar 2001
    New York
    ace2,
    Your welcome.. and thank you too.
    -vhelp
  7. That is a problem with Virtual dub. Most programs of any sort will add the correct extension to the file you are creating; text editors add .txt, mpeg editors add .mpg, etc. Virtual Dub looks and acts the same as any other program but it doesn't add the extension for you so if you don't remember to add it before commiting the action your output file will not have the correct extension.
  8. Problem might be a strong word for this. It only needs you to type the extra 4 characters (.avi) Easy to do, and it's a great tool
    Nov 2002
    I've been using VirtualDub for three years and I have never seen this problem with the .AVI extension. It produces the file as xxx.00.AVI or xxx.00.00.AVI depending on how many files have with the same name.
    I have noticed when saving a wave file that you must put the .WAV extension on though. For some reason it refuses to do so.
    I still using version 1.3c.
