Hi there,
I have the following problem, maybe someone can help me?
I captured DV in Premiere 6.5. Now I want to convert the DV to MPEG 2 (SVCD-Format) using the LSX Plugin for Adobe.
Well, it works fine - but when I burn the stream on CD-R and watch the SVCD in my DVD-Player, the edges of the video are "jittering" (I mean the upper and lower margins). Everything else is ok.
Has someone else the same problem or has someone a hint for me, how to solve the problem. I am experienced with DV and converting, so I do not make any "beginners-faults" (sorry for that term). The problem appears not only on my DVD-Player...
Thanks in advance
Burny.
why don't you try using the encoder that comes w/ 6.5 alone with the update patch ? it is considered to be better than Ligos .
Yeah, I would like to - but in the export-settings, I can't see the stand-alone MPEG-Encoder from adobe! Has it something to do with the update-patch? If yes, where can I get it? At www.adobe.com I can't find it!
Burny. -
there is a problem if you upgraded from 6 to 6.5 and many of the plug in dont work ..
you can't upgrade only new install of 6.5 , then it works ..
http://www.mainconcept.com/adobempeg/downloads.html is the update though
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Premiere MPEG for DVD setting
By CircusAim in forum Newbie / General discussionsReplies: 5Last Post: 22nd Feb 2010, 12:23 -
Replacing mpeg to avi in Adobe Premiere
By Cyroq in forum EditingReplies: 7Last Post: 7th Oct 2009, 13:57 -
Premiere Pro CS3 MPEG-2 Compatibility
By cyberboy in forum Newbie / General discussionsReplies: 3Last Post: 1st Dec 2008, 14:58 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 22:48
