  1. Is there a possibility to convert a videofile created with windows moviemaker to a format that is readable for a dvd player and if so what program should I use ??
    Already tried TMPGenc, latest version, but that doesn't seem to support wmv files.
  2. Banned
    Jun 2001
    UK
    TMPGEnc does convert WMV, do you have the correct codecs installed ? or is the file protected ?
    Test your system see what you can edit/play
    http://www.vcdhelp.com/forum/userguides/135552.php
    See one of my old posts on WMV/ASF with Graphedit
