How Do You Burn CVD???
As a SVCD or do I need a special program?
Nope, use whatever you use to burn SVCDs...
Although Nero might complain, just burn as non-standard. -
CVD is basically a SVCD but with a resolution of 352x480 and a higher bitrate...
Just burn it as a SVCD non compliant -
CVD follows same bitrate requirements as SVCD, not higher. If you go higher than SVCD, you've got an XSVCD, not CVD.
/\/\ars /\/\ayhem -
Here's a guide explaning CVD:
http://www.vcdhelp.com/forum/userguides/98177.php
Hope That Helps!!! :P
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
