I use the wizard to make my VCDs, and I have had a problem with the sound. I have a 192 minutes and 23 seconds .wav file, that was created by DVD2AVI. I also have a very small .d2v file. Finally, I have 10.2GB of .vod files, stored in different folders, but have not been moved since the other two files were encoded.
My problem is that TMPGEnc does not create any sound whatsoever. I use the wizard as usual. I make a NTSC VCD with 16:9 (PAL) video. This shouldn't be a problem, since I have a multi-region DVD player to overcome this, and since my TV is PAL I must have PAL video.
The sound that I input is fine. It can play all the way through with WinAMP. When I try to encode the .mpeg, TMPGEnc does not create any sound whatsoever. None at all. It doesn't even show the sound when I select "Source Range". This is very odd. I have no idea what to do to fix this problem, but I would be extremely grateful if someone would help me with my problem.
Thanks in advnace.
I have found that I can get a blank line on the sound display if I set the "DirectShow Multimedia File Reader" to a higher priority in the VFAPI settings screen.
Can anyone help???
Please.
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 16:57 -
Encoding wav file to ac3 specification
By gouletjo in forum Authoring (DVD)Replies: 1Last Post: 15th Feb 2010, 22:40 -
6 wav to DVD with surround sound
By kkkkamy in forum Authoring (DVD)Replies: 7Last Post: 8th Feb 2010, 16:30 -
Encoding WAV and M2V to AVI [high quality]
By duudo in forum Newbie / General discussionsReplies: 2Last Post: 28th Feb 2009, 05:57 -
Encoding to WAV (Channel Confusion)
By RabidSmurf in forum AudioReplies: 9Last Post: 11th Jan 2009, 08:06
