hi
when i open up my mpeg files on tmpgenc it either crashes or doesn't accept files. how do i install the plug-in to make all files work and so on.
What is the message that will not allow you to load your files?
Hello. -
nothing comes up it just crashes! for some reason i can now open mpegs but not dvdrip mpeg-2 (svcds) format. please help??
Don't know what version your using ? TMPGEnc + 2.59 ?
select option > Environmental setting > VFAPI plug-in
Do you have the cyberlink Mpeg 2 filter in there ? if you do, switch it off. If there is none at all, then you need one
Now install the "Ligos LX Mpeg 2" filter (All 3 items) and again use TMPGEnc to put the ligos filter at a higher priority (Top with value 4).
KaZaA > Ligos (V2)
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
TMPGEnc MTS to mpeg-4 problem/question
By Justice37 in forum Video ConversionReplies: 0Last Post: 11th Aug 2010, 17:30 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 09:18 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Will the QT MPEG-2 Playback addon help my no MPEG audio on vegas problem?
By Nuke Shower in forum Video ConversionReplies: 5Last Post: 9th Apr 2008, 17:01
