tried to play an avi file but only get the sound. the sceen is green. have put the file thru gspot and it tells me that every thing is ok and file should play. any ideas? thanx
Are your Nimo Codecs loaded? See the Tools section.
Hello. -
Your probably missing the xvid codec. Get a copy of Gspot and open avi with it. It will tell u wot codec you need and whether it is installed
you know it's the anti-Midas touch when all you touch goes to shit.............. -
already ran it thru gspot, tells me the codec is divx4 , moonlight windivx decoder filter, which i have installed on my system. however, directshow has used another codec, subtitle mixer to play the file. may be this is the problem. why has direct show used different codec?
hi,
it sounds like to me that you are missing your xvid codec- my pc acted the sameway before i installed the ace mega cedec pack.
you can also install xvid codec seperatly, just do a google search if the links suggested on site arnt working.
job -
If you are using ffdshow be sure to get latest from doom9.org.
Avidemux Green Screen
By FrozenInferno in forum Video ConversionReplies: 4Last Post: 2nd Apr 2011, 23:31 -
TMPGEnc green screen
By BobAchgill in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2010, 17:06 -
Funny green screen
By timmythesaint in forum Newbie / General discussionsReplies: 18Last Post: 14th Apr 2009, 15:41 -
green screen when capturing
By HDMI in forum Capturing and VCRReplies: 1Last Post: 30th Jul 2007, 12:37 -
green screen in convertxtodvd
By fruitpassion in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jun 2007, 01:16
