I'm using iuVCR to capture 8mm analog tapes to Huffyuv AVI format and VirtualDub to apply filters (smoother, deinterlace) to clean them up before encoding to a SVCD. However, when I play back a edited file from VirtualDub, the AVI video and audio hangs up within seconds. The "unedited" AVI video from iuVCR is appears to be ok prior to using VirtualDub. Any ideas? Are the settings/options in VirtualDub correct?
Capture settings - iuVCR
video - 720x480, YUY2, Huffyuv, NTSC, 29.97
audio - PCM, 48kHz
Interleave - none
Edit settings - VirtualDub
video - full processing mode
filters - temporal smoother, deinterlace
frame rate - no change
Compression - Huffyuv
audio - direct stream copy
enable audio/video interleaving
preload 500ms of audio before video starts
interleave audio every 1 frame
Results 1 to 1 of 1
MeGUI hangs on pre-processing after extracting audio tracks
By CasanovaFly in forum AudioReplies: 2Last Post: 31st Jul 2011, 10:25 -
AutoGK hangs when importing an AC-3...
By takearushfan in forum EditingReplies: 6Last Post: 28th Jun 2010, 07:58 -
Vista hangs getting ready to import video (prog not responding)
By ambushed19 in forum Capturing and VCRReplies: 2Last Post: 11th Aug 2008, 20:59 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 14:23 -
SVCD2DVD Hangs
By chucky246 in forum SVCD2DVD & VOB2MPGReplies: 31Last Post: 3rd Jul 2007, 06:28
