Hey Guys,
I was wondering what the quickest and easiest way would be to make a compliant DVD if I only have the VOB files and not the ".BUP" or ".IFO" files for them,
Thanks![]()
Good question...
Well, anyways, if it can't be done just by "copyin', droppin' and burnin'", you can always convert your .vob to .mpg and burn it with authoring soft like DVD Workshop, right?I shall show you... ETERNITY -
Follow the Ifoedit info below wolf109 put. Great info to have. Never stop learning.
Ifoedit will create al four required ifo files from a vob file. Just rename your vob = VTS_01_1.vob. It will create the needed files for any burning to accept. You don't need to author.
i have a similar dilemma...how do i make a dvd just with the .vro ?
to dvd or to dvd
Creating ISO from VOB's
By chronic777 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2009, 14:36 -
Problems creating DVD from Vob files
By 1234567 in forum Newbie / General discussionsReplies: 16Last Post: 21st Dec 2008, 16:43 -
Creating TS from VOB??
By boofus in forum Video Streaming DownloadingReplies: 4Last Post: 29th Sep 2008, 19:02 -
editing DVD (vob) clips and creating a new DVD with menus
By gappman in forum Newbie / General discussionsReplies: 1Last Post: 5th Sep 2008, 09:30 -
ULead Videostudio - creating a DVD from a single large VOB file..
By djdust in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2008, 14:34
