I have several MPEG-2 files created by TMPGEnc from captured DV/AVI files. I want to merge the mpeg-2 files together using TMPGEnc's merge facility. When I do that, the audio begins to get out of sync - progressively worse the farther into the reulting file I get. It is probably less that .5 sec out of sync at the end of an hour long mpeg made up of 19 smaller mpeg files. I did notice that the times reported by the "Outputting ..." dialog for the video and audio are 3730.46 seconds and 3730.68 seconds respectively
Any Ideas why??
I've asked the same question a while ago... I also experience this and cannot figure out what the problem is
I have tried some other programs that join mpeg-2 files in which the audio and video were in sync at the end of the hour, but the timecodes/frame information was screwy. When I tried playing the file in WinDVD, it thought the duration of the entire mpeg was the duration of the first clip. When I brought it into tmpgenc, it only recognized the first clip, and when I brought it into Dazzle DVD Complete, I had problems moving the time selector on the timeline around.
I am wondering if anyone has found a program that will join MPEG-2 files together correctly, or if there is some other way around this problem.
(I have tried most of the shareware/freeware programs listed at http://www.digital-digest.com/dvd/downloads/encoding_cutjoin.html so please don't reference those)
Thanks,
Tom -
exact same problem but i'm using mpeg hope some1 figures this out or gets another program-vcr.
how do you do this in TMPGEnc i only want to link four files together but when using TMPGEnc you have to make a whole new file and create a whole new Mpeg file and on all the options i've tried the quility always has lines onthe edges of everything on screen.
all i wanna do is link these four files together and keep audio in sync.
pls help
Have DVD Files, need to merge subtitles into MPEG
By geekfemme in forum Video ConversionReplies: 3Last Post: 2nd Mar 2011, 19:07 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
Very basic question...... how can I merge mpeg files and make a movie
By True Colors in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2009, 16:45 -
problems with avc to mpeg-2 in tmpgenc xpress 4.0 - more than 3x run time?
By NoFace in forum Video ConversionReplies: 3Last Post: 18th May 2008, 21:01 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46
