HELP!!!
I'm using spruceup to compile a few films onto a DVD-R. It compiles everything ok, but when it comes to burning the DVD-R it comes up with this message, "The remaining disc write operations will be aborted." I can't find a way to prevent this from happening. It only happened when I cancelled while it was compiling and now it comes up with this message all the time. Does anyone know how to get around this, any help would be much appreciated![]()
don't write a dvd with spruce-up ... create an image and burn with a program like prassi
Let it compile the DVD to the SpruceUp Working Directory and then drag the Video_TS directory into Nero or what ever burning program you have.
Thanx for that. I've tried it and it worked fine on the first two films on the DVD-R, but the third one seems to pixalate a little bit. Is there anyway around this.
Pixelation indicates low bitrate and I doubt there's any cure for that. Three "films" on one DVD-R is pushing the limits,consider only two per DVD-R.
I have put more films than this on a DVD-R before without any problems, it's only just recently these problems have occured. My first attempt consisted of five films with approx. 90min runtime for each film and not one film had any problems and the disc worked fine on quite a few different standalone players.
If your only interest is how much time you can sqeeze unto a DVD-R then use standard VCD 2.0,you can get over 7 hours on a DVD-R and it will be DVD compliant.
I'm not just interested in squeezing as much on a DVD-R as possible. I've got a lot of videos which I am backing up and the majority of them are films which have quite a few sequels / prequels etc. and it just seems pointless putting just two films out of a trilogy on one DVD-R. They have been encoded to VCD 2.0 and all but my last one have been very good.
AVStoDVD ERROR DURING OPERATIONS ('DVD Authoring operations' Section): 0
By avitodvdbabe in forum Authoring (DVD)Replies: 0Last Post: 22nd Oct 2011, 17:14 -
AVStoDVD Video Encode Abort
By WritePublishDie in forum Video ConversionReplies: 5Last Post: 28th Feb 2011, 13:25 -
AAC Decoder Operations
By Dave1024 in forum AudioReplies: 0Last Post: 16th Dec 2008, 03:26 -
Can a 4x burner write to a 16x disc?
By bobarnett in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Sep 2008, 16:47 -
write 2 movies in 1 disc
By akakiami in forum DVD RippingReplies: 6Last Post: 10th Sep 2008, 08:06
