I just found this video card on ebay
It's called WINSONIC. It's usb. It has capture, tv in, radio and it is remote controlled.
Here is the link
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3708&item=2087549408
Anyone know anything about it. one thing I noticed was it said it need so much space for windvr installation. Is this just a re-named product. I am trying to see if there are any products with pictures so I can compare it to another brand. I can't find any info on winsonic.
Any help will be greatly appreciated
Signed
VCD4ME
We were all NEWBIES once and the only stupid question is the one that's not asked?
Very little on the net about that device, mostly on auction sites. Not a promising thing.
Panasonic DMR-ES45VS, keep those discs a burnin' -
Thanks Kitty.
Ok I did some more research and came up with two others that basically look the same the question is who is the real manufacturer.
one is from tigerdirect and is called orca usb tv
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?sku=O38-1002
The other is from www.kworld.com.tw (I think this may be the real manufacturer)
Also I think this looks similar to a usb card that I saw at compusa maybe I'll go there tomorrow and check it out
The main reason I want to find out about this is because it has a remote.
Anyone else know anything about these companies please let me know.
Thanks in advance
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked?
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 02:02 -
No sound in WME with USB capture card
By bomb jack in forum Capturing and VCRReplies: 2Last Post: 25th Feb 2011, 04:40 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2010, 06:50 -
USB 2.0 Video Audio capture Card
By jj3502 in forum Capturing and VCRReplies: 0Last Post: 3rd Feb 2010, 05:09 -
Can Easycap Video Grabber Capture card USB 2.0 RCA be used to record Beta
By laslim in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2008, 11:06
