  1. can anyone help i am trying to use quicktime pro to split and save an avi however every time i try to do something a popup says quicktime is running out of memory and cannot do the task. So the question is can i allocate more memory to quicktime and if so how?
    thanks anyone
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    What OS are you running, and if it's 9.x or earlier, do you have virtual memory turned on?
