Hi, I am trying to rip a DVD to a SVCD. I open Smart Ripper and it is saying aspi nopt found. What causes this . I am using a brand new dvd-rom/cdrw combo drive. Thanks for the help!!!!!
need to know the version of windows you're using. If you're using xp download aspixp and install it and your problems should go away, if you are using another version of windows download the other versions of adaptecs aspi driver and install them instead and smart ripper should be fine. Of course there's linux, which I really don't know about..
Can you play the DVD in your drive ?, play it first then run smartripperOriginally Posted by jsn3027
ASPI update
http://www.adaptec.com/worldwide/support/drivers_by_product.html?sess=no&language=Engl...duct/ASPI-4.70
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 17:48 -
problems with Mac the ripper 3.0 R14i
By andyx181x in forum MacReplies: 12Last Post: 4th Dec 2007, 20:51 -
DVD Decrypter problems - I want the very best DVD ripper
By Lovepeaceguru in forum DVD RippingReplies: 3Last Post: 11th Nov 2007, 20:54 -
Problems with Mac Ripper
By AbelCastro in forum MacReplies: 7Last Post: 21st Jun 2007, 09:46 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 02:15
