    Jan 2003
    East 'Ull
    Which card would you recommend with a TV out function.
    I want to relay my VCD/DVD's from PC's pioneer player to my TV/video set up.
    Can the audio/video signal be manipulated so my video receives 'enhanced' audio ?
    My TV/Video set up is UK (pal) and connection will be by the usual 3 wire audio/video.
    Help and advice appreciated.
  2. I have not tried a single video card (VGA) that has good quality video output. The only card(s) is the stand-alone mpeg cards like the Hollywood Plus cards. They will output high quality standard compliant video, and not the "quasi" compliant video output you get from a VGA card.
