used the unlock template and adjusted my pixels to 480x480 in the vcd mode, is this possible caus the outcome is the picture wont fit on my tv, either to big or only get portion of top of movie, tried the svcd trick by converting to vcd but get same picture, not fitting, i want the bes picture quality possible on a cdr but dvd home wont play mpeg 2 or svcd types? Even when using the header trick picture still does not fit, either to low or to big, tried like 7 cdr's and now i have beer coasters?
The VCD header trick does not work with "all" DVD players. I suggest you look up your make/model of DVD player in the DVD Players section at www.vcdhelp/dvdplayers and read the comments for your particular player. Those comments should tell you wether or not the header trick works and also give you possible insight into other problems/fixes.
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 10:42 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 09:36 -
Is there some trick to putting in a video card?
By videobread in forum ComputerReplies: 12Last Post: 21st Jun 2007, 22:07
