  1. I am using TMPGEnc to convert DIVx to MPG but every time i do it gives me an error saying:
    read error occured at adress OCX987760 in module TMPGEnc.exe
    its really getting annoying as i have so many movies to convert??
    any ideas
    if not what other methods of converting are there?
    MAC
  2. I have same problem and have sent my pc for repairs. If you look on the forums at www.afterdawn.com and search the forums for tmpgenc errors there is an explanation about read access errors being associated with bad memory sectors.
    Hope this helps
  3. try defragmenting your drive since someone said that the error occurs of bad memory sectors..hope it works...
