I am currently trying to burn monsters, inc to dvd+RW. I used dvd decrypter to rip the entire movie in file mode. I want to keep the structure of the dvd menu so that I can use the chapter selection menu and audio selection menu.
I started by deleting the vob files not needed (4x3 aspect ratio, sneek peaks, etc.) I kept the ifo, bup, and vts_*_0 files of every vts as I heard these are sometimes needed for playback. I then stripped vts_05_1 of the fbi warning and copyright notice. Next I moved all the old files I needed from the original folder to the new folder with stripped vob. Then I opened each ifo file in ifoedit and pressed get vts sectors for each file.
when I go check the playback in powerDVD everything is exactly how I want it. However, when I attempt to burn using RecordNow I get an error and the file won't burn. It does not tell me what's wrong it just says "data job terminated with errors." I then tried to burn using nero udf 1.02 mode. It burns the disk, however it does not play in computer or standalone, which tells me something is wrong.
Any suggestions?
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Lagarith + UT codecs are HD "space" monsters !
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 17th Sep 2011, 19:08 -
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 05:54 -
IFOEdit - Author DVD - Chaps Failed
By mattstan in forum Authoring (DVD)Replies: 2Last Post: 6th Nov 2007, 06:44 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 15:37
