in vcd easy i get a message that ays i am either" missing , or was not installed correctly, c:\windows\system32\wn aspi32.dll . the program says CDRAO support is disabled. any advice would be greatly appreciated as this is really new to me as i just bought a capture card today and, well you know the rest lol.
In VCDEasy, in the bottom right corner, does it say ASPI seems valid: yes, or ASPI seems valid: no? If it says ASPI seems valid: no, that is your main problem. In that case I suggest you go to: http://www.afterdawn.com/software/cdr_software/cdr_tools/frcaspi.cfm , download the ForceASPI drivers, install them and reboot. If after you reboot, it shows "ASPI seems valid: yes" then on the CDRDAO settings page, select generic-mmc as the force driver for the CD Writer, select your specific CD Writer in the dropdown menu for that section and check the force execution box. Now you should be able to burn using CDRDAO, which is the CD burning program built in to VCDEasy.
If you don't have a Adaptec product, you could always install one with the add new hardware
then you can install the Adaptec software without force
http://www.adaptec.com/worldwide/support/driverdetail.html?cat=%2fOperating+System%2fM...=aspi_v470.exe
video file and subtitles file are out of sync because of missing intro
By bmaya in forum SubtitleReplies: 3Last Post: 13th May 2010, 11:26 -
BD_Rebuilder Bug or File missing
By Raul124 in forum Blu-ray RippingReplies: 1Last Post: 18th Nov 2009, 02:01 -
Windows XP startup file missing
By SE14man in forum Newbie / General discussionsReplies: 12Last Post: 7th Oct 2008, 10:35 -
Missing a .VOB file?
By Ego Tripper in forum Newbie / General discussionsReplies: 5Last Post: 2nd Feb 2008, 16:02 -
Missing Sensapi.dll File.....Need Some Help!
By RKelly in forum ComputerReplies: 2Last Post: 31st Jul 2007, 16:20
