This is what I do:
I started with downloading a movie (.avi, divX) with AC3 sound in.
I used the Headac3he software to reenoced the ac3 audio to mp2 audio, and this part worked fine.
Then I started TMpgEnc and used the wizard as described in the "how to" section for SVCD on VCDhelp.com.
This looked like it did that part allright too.
Then I used MaestroSBT to make subtitles from a .ssa file, and the result was a lot of .bmp (4 bit, uncompressed) and a .sub (for SubMux).
Then I used WinSubMux to Mux the old .mpg with the subtitles from MaestroSBT, and this process finnished without any errormessages at all.
Finnaly I used VCDEasy to make The SVCD image and actually burn the SVCD.
BUT !!!! No subs shows up on my standalone player, and I DO remember to select a subtitle stream on the player.
To make a little more weird I have downloaded the SVCD PAL sample from vcdhelp.com, and when I burn this image to a SVCD it works...
I guess my trouble starts somewhere between MaestroSBT and VCDEasy, but I have tried a lot of ways to get there.....
Can anyone please help me?? What am I doing wrong ??? Are there any special considerations to have in mind when doing any of these steps.
What resolutions must I use in MaestroSBT, and what subtext colors...
PLEAAAAAAAAAAAAAASE HELP !!!!!
/Zep
I forgot to say that VCDEasy actually CAN see that there is a subtitle on stream 0x00
/Zep -
Zephyrus
I´m having the same problem,
Have you already found the solution??
Viewing subtitles with BD Rips
By vhgrub in forum MacReplies: 0Last Post: 23rd Aug 2009, 16:04 -
Sony Vegas 8.0, trouble viewing video clip
By ir0n_ma1den in forum EditingReplies: 8Last Post: 10th Jun 2009, 20:36 -
I am viewing some movies. If BVOP is off. Would it not play on standalone?
By rocky12 in forum Newbie / General discussionsReplies: 14Last Post: 27th Nov 2008, 08:32 -
Gray shade in subtitles when [b]avi[/b] file is played in standalone player
By huRO in forum SubtitleReplies: 2Last Post: 1st May 2008, 14:15 -
why not all standalone player show subtitles after author with DLP ?
By pcb in forum Authoring (DVD)Replies: 0Last Post: 19th Feb 2008, 05:43
