I just installed TempGenc 2.58, but when i try to convert filesit takes way too long. For a 71mb file it takes 22 hrs. I went to the common problems section of this site but the tips didnt reduce the time. Please help me
What is the file type your converting ? has it been checked for bad frames ? Try using the source range (End at a few frames from the end)
Also check this
TMPGEnc
Options > Environmental setting > VFAPI plug-in > DirectShow multimedia file reader > right click, select higher priority (Do several times to get it at top) or just below any Mpeg 2 filter -
I also noticed that TmpGenc does not use much of my cpu. I have coolmon and it indicates that only 15% of the cpu is in use by Tmpgenc. The use of the cpu also fluctuates, which means that sometimes it will use 15% then 0% then back to 15%.
.mov as in Quicktime ?... is that filter at the top ? they are always slowOriginally Posted by blank00
First time ever a problem
By Randalliser in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 10th Oct 2010, 14:53 -
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 15:21 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 22:39 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 02:35
