I have extracted the Chapters using both DVD Decrypter v3.1.4.0 and Chapter Xtractor v0.961 ensuring they are in the DVD Maestro ( *.chp ) format. When i go to import the chapters into Maestro i just get a "0 Chapter Points Imported" message, NOT the I-Frame error message everyone else seems to have.
Anyone know how to solve this problem ? I don`t fancy adding the chapters manually![]()
Cheesemeister2000
On the Chapters right before I open the original ifo to extract my chapters using chapterxtractor i make a minor change.
I select presets for DVDmaestro then I make a change to the format.
I change the colon after %ss and before %ff to a semicolon. Then I open that original ifo and save my chapters.
%hh:%mm:%ss;%ff\n -
I Know you said that you didn't want to make chapters manualy, but i would advise you to do so.
I always had problems importing Chaper.chp into Maestro, so i decided to make make my own.
It doesn't take that long, and you can make as many or as little as you want and it's a hell of lot better than importing them into Maestro.
On the Chapter window in Maestro, just click on timeline, a window will popup just click ok, and thats it.
Repeat the procedure for as many chapters as you want to make, it should take no longer than a mintue or so to do it. -
never had a single chapter prob with chapterxtractor in dvdmaestro mode then put this in the format tab: %hh:%mm:%ss:%cc
But don't do like it says in a tutorial on Doom9 (copy paste in a text file) cause that didn't work for me, just save as .chp and it will do the trick.[-Neoh*-]|[-Cheers-] -
I've had that problem a few times.. i don't recall, but I think it happens when you run chapter extractor on the ripped vob's, v.s. off the DVD.
However, I don't totally recall, I've only seen it happen once.
Plus making your own chapters is pretty easy, so it's not a big deal.
-d
Nero Recode 2 Chapter Mark "Creep" vs. Original DVD
By CobraPilot in forum DVD RippingReplies: 4Last Post: 16th Feb 2012, 23:29 -
MPCHC puts a chapter "subtitle" on the bottom of my mp4s
By brianp6621 in forum Software PlayingReplies: 2Last Post: 19th Oct 2009, 13:35 -
virtualdubmod EXample file for "import chapter" function?
By KneeRow in forum Newbie / General discussionsReplies: 2Last Post: 9th Jul 2009, 12:07 -
Re: making "live" chapter button with windvd creator 2
By tomcat862 in forum Authoring (DVD)Replies: 0Last Post: 28th Feb 2008, 13:13 -
dvdauthor problem "chapter doesn't exist"
By ecc in forum Authoring (DVD)Replies: 2Last Post: 28th Jan 2008, 09:54
