I have a W2K machine on which I convert from DV-AVI to MPEG2 using TMPGENC. Since it is a 1 hr movie I made several smaller AVIs so I can make changes without having to renders too long again.
Then I encode to MPEG2 for DVD using TMPGENC, I get no encoding errors or the like.
After that I join all the MPEGs using TMPGENCs MPEG tools.
When playing each AVI they all fade to black as they were made but when encoded to MPEG2 they and joined to one big file they end 1..3 seconds before the fade out and the next clip begins. About 6 out of 10 clips simply stop.
Could it be that the MPEG read codec on my system is out of date or something like that ?
How can I tell which MPEG2 codec is in use and how could I try another ?
Thanks for any hints or other isdeas hat's going on here.
Werner
try gspot it will tell you what codecs you need for playback it is in the tools section
Need help with codec for .flv playback
By 2ndHandGizmo in forum Software PlayingReplies: 2Last Post: 2nd Mar 2012, 10:53 -
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 00:35 -
proprietary codec used by Sharp for MPEG2
By ghostma in forum Software PlayingReplies: 17Last Post: 16th Nov 2011, 17:11 -
Handbrake playback codec?
By jfharper in forum Video ConversionReplies: 2Last Post: 8th Nov 2011, 19:52 -
Snow codec playback
By leghorn in forum Software PlayingReplies: 2Last Post: 6th Jan 2009, 05:06
