I've done a search and couldn't find my issue.
I ripped my first dvd to my hard drive yesterday using
DVD2VCD and it worked great! I used Windows MP to play
the mpeg files (three of them) and I tried to use Nero to burn
a svcd disk. I dropped the mpeg file into the window and burned
the cd without error. But it doesn't play. Is there more than just
the mpeg file to place into the burn window?
I'm sorry if this is stupid, I'm new to this.
Any help would be appreciated.![]()
I suppose you're missing the small program from Nero website called MPEG PlugIn about USD9.oo download. You need this small patch program to decode Mpeg files before you can burn your files into SVCD or DVD
jwsons -
Place the disk in the CD-ROM drive and open to view, can you see the large mpeg file in one of the folders ?, if you try to play that, does it work ?Originally Posted by Costa
The big-ass mpeg file plays fine (I used windows MP). I'm not sure whether I need to drag 'n' drop more than just the one file into the Nero window.
I burned one of the mpegs to vcd just fine and then tried to play it with MP, but it came back with 'cannot play the file' In the details it alludes to an unsupported format. However, Nero burned the vcd just fine. This is why I'm confused. -
Did you make a mpeg 1 (VCD) then tell Nero to make a Mpeg 2 (SVCD) ?DVD2VCD and it worked great! I used Windows MP to play
a svcd disk
Don't use Nero to convert from Mpeg 1 to Mpeg 2 use TMPGEnc
Also you could convert direct to SVCD with programs like DvdX
Install the Ligos filter, then you can also use TMPGEnc to convert from mpeg 2 to Mpeg 1
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 23:04 -
Nero burning DVDs from the outside in?
By 2prfm.com in forum Authoring (DVD)Replies: 12Last Post: 19th Jun 2008, 22:47 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 09:35
