  1. hey i have been trying to rip a dvd now and i am using pinoy's guide and its all worked succesfully until i get to tmpgenc. when it says load the d2v file, i go to do that and when i do it says "unable to load .d2v because its not supported. i have all the settings correct and i need help here!
    Thanks in advance
    Justin
    :agree:
  2. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Thanks in advance
    Check the environmental settings and increase the priority for the plugin.
    If you don't have it, you need it.
    Was it really that urgent?
    Will
