  1. I have burned vcd using vcdeasy. I used heady trick (ie SVCS to VCD)
    Whislt all plays fine on PC the sound is out of synch on standalone sony DVD player
    Can anyone suggest any tweaks to do
    Paul
    Dec 2002
    devon UK
    My LimitDVD9090 requires that I put a time delay of 500ms on the mpegs to sync properly (for VCD, no delay for SVCD) so it may be the way your DVD player is processing the sound. Try making a test disc with say 8 tracks on it 30seconds long each track having varying delays of 250ms to suss out what your DVD player is doing?
  3. OK...Help... do I adj on multiplexing in tmpeng or when I burn using say vcd easy or Nero??
    Or is it an adj on encoding to mpeg??
    these damn sony machines!!1
    Cheers
    Paul
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You can adjust the audio delay in the Source Range window of TMPGEnc when encoding.
