Hi,
I like to know if I can convert a mpeg1 file to a mpeg2(DVD) format, because I can create mpeg1 files with my Studio MP10 (at 2200 Kb/s)and I wanted to reduce the files size without losing the quality. After converting can I run and see the new mpeg2 file in my PC (with Windows Media Player)and in my DVD Player ?
Thank's
AC
yes and yes.
i've had low video bitrate (850-950kbps) 23fps mpeg-1 VBR XVCDs which stuttered on playback on my standalone. so what i did was
1 - convert the DAT (from the XVCD) to MPEG
2 - load the MPEG in TMPGEnc
3 - load the DVD template
4 - load the unlock template
5 - disabled interlacing and 3:2 pulldown to make it 29.97fps progessive
6 - modified rez to 352x240 (rez on original XVCD)
7 - changed CQ to CQ_VBR 0-9000 (TMPGEnc will only use the max bitrate required for encoding each frame)
the output MPEG-2 file played smoothly on my PC and actually looked better than the original MPEG-1.
i then loaded the MPEG-2 into TMPGEnc and re-encoded it back to a low bitrate 29.97fps XVCD which plays smoothly on my standalone (my standalone won't do MPEG-2/SVCD).
<font size=-1>[ This Message was edited by: hitechjunkie on 2001-08-31 11:47:11 ]</font>
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 15:25 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 11:58
