I've been using DVDPatcher to fool Maestro into accepting SVCD sources for authoring. I've been setting the bitrate to 3.5mbits instead using the setting the original source has.
So far, I haven't had any issues (works on a variety of systems, including PS2's), but I was wondering if I should in fact be setting the bitrate to the original's pre-encoded rate?
Thanks.
AIR.
Not sure you will have problems leaving it as 3.5 but setting it the same as the soruce could save yourself hassle if anything goes wrong or if you want in future to put the files back to svcd..
Fantastic program aswell -
I think it doesn't matter. The value is simply re-wriiten in the mpeg headers (instead of the value written there by the encoder).
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Avchd patcher
By srfdude in forum Blu-ray RippingReplies: 4Last Post: 25th Feb 2010, 00:01 -
Where to download AVCHD-PATCHER 1.06? It has vanished?
By siratfus in forum Blu-ray RippingReplies: 5Last Post: 8th Jul 2009, 05:42 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:31
