I've captured from a digital source (sky tv - uk Pal) and no matter what settings I capture I eventaully get sound and video out of sync.
I use Virtualdub to capture with the PicVideo codec (quality 18), 720 x 576.
I lowered the PicVideo quality to 15 and the format to 480 x 576 then down to 352 x 288
I'm intending to output to dvd.
The out of sync is noticable before I encode the avi with TMPGEnc.
I'm getting hardly any frame loss, can anyone assist?
Thanks,
Will
Alum Chieftec Scorpio TX-10BWD Case with Antec 340w PSU
AMD Duron 800 (Athlon 2000XP come the 6th Jan!)
Elite K7S5A motherbaord
512mb PC133 Ram
ATI Radeon 64mb DDR ViVo
IBM Deskstar 30GB Primary HDD
2 x Maxtor D740X HDD's on RAID 0
Soundblaster Live 1024
Lite-on CDRW Drive
Pioneer DVD-Rom Drive
Panasonic DVD-R Drive
EA900 ADSL Modem
WinXP, SP1
Results 1 to 19 of 19
If you are capturing the PAL TV format, try adjusting the frame speed to exact: 24.964fps.
I am having the same problem with Huffyuv capturing on 25fps which isn't an accurate setting. The only way to fix it is to set the frames to the exact speed required for the sound to match with the video. I hope this helps. -
Hi
What software are u playing your captures back in??
If it's WMP use another one.
My captures (and a lot of my movies come to that) are out of synch when using WMP but they are fine in PowerDVD and other software.
Fozzee -
Thanks folks,
I'll give both suggestions a try and report back.
Unfortunately I deleted all the out of sync captures in a fit of rage so I'll do some more!
Thanks again,
Will -
WOW! Getting into a rage won't do you any good and you could've used VirtualDub to correct the problem.Originally Posted by Silky31
There is an area you can video process to get the sound in sync with the video and doesn’t take long to fix with file size remains the same. -
I was joking.Originally Posted by CJGS
I don't think that fixes progressive sound issues.Originally Posted by CJGS -
The PC videos I was fixing with VirtualDub were interlaced from television. VirtualDub's processing did it fixed for me, no problem.Originally Posted by Silky31
So, I know how to stop the video and sound out of sync during capture at the first place. Just fix the setting of the frames as exact: 24.964fps for PAL. -
Hello,
I tried your 24.964fps idea last night but for some reason the fps rate I was getting hovered around the 15fps mark - very strange, I must have done something wrong.Originally Posted by CJGS
I'll try again tonight.
Could you give me a brief walk through on the Vdub sound fix?
Do you know if it will work with mpeg's (created with TMPGEnc) without re-encoding?
Thanks,
Will -
I know this works for me and good luck.Originally Posted by Silky31
You visit into one of the guides on the left: http://www.vcdhelp.com/mjpeg.htm
This is the steps to correct the sound:
If the sound is out of sync
Open the captured file in Virtual Dub. Choose "Frame Rate" under the "Video" menu. Choose "Change so video and audio durations match". Before saving, make sure you have selected "Direct Stream Copy" under the video menu and Full processing mode under the audio menu.
I can't really help you with the question on whether it will work with mpeg's (created with TMPGEnc) without re-encoding? I haven't tried this one yet.
So, I hope this helps and I know not everyone gets success. Good luck. -
Many thanks, I'll try tonight/tomorrow.
Best regards,
Will -
your a lengend CJGS
i ran the file through VD with change frame rate thing like you sugested and it worked!! perfect sync
i will try the 24.964 frame rate capture now to save the whole procedure
but i am curious to know..... why when i used to capture with my BT878 based card in VD i never had this problem,
now using Virtual VCR and iuVCR with my new CX23881 based card i get this out of sync problem
what does VD do that the others dont ??
or is it the immaturity of the CX23881 chipset drivers ??AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
Jabber: DaveQB@jabber.org.au
2.6.29.3-desktop-1mnb -
To DaveQB -
I don't really know why, maybe difference apps with the default capture card drivers. Difference apps with different capture cards seemed to be the issue as well.
The bigger the resolution is the problem with the sound out of sync. So, the computer’s specs make a difference too. It must handle it.
For me, the exact frame rate only applies to huffyuy with a size of 640x480 and greater. A smaller huffyuy 352x288 is fine using 25fps.
Anyway, VirtualVCR wouldn't work for me. My comp froze and crashed and WMP wouldn't load with VirtualVCR's captured huffyuy. -
thanx
i tried 24.964 but it didnt make it sync,
did help thouhg, not bad, but still out after 30 mins
i guess i am going to have to run each file thru VD with the Change Frame Rate thingy
it wouldnt hurt to do that during the encoding and filtering etc ???
saves running through the file twice
and yah i never capped any higher the 352x288 in VD, so maybe if i did (installed BTwincap etc) then i might have had the same ?!?!)
PS one guy using same chipset and iuVCR said he uses 48000hz for sound, so i am trying that now....AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
To DaveQB -
You can try and experiment in different ways. Try another sound is a great idea. No harm in that.
Some might work for you and others may not. Good luck mate.
I'll be experimenting NTSC capturing soon. I hope problem free.
regards
Chris -
NTSC capping ??
but ur in Oz like me ?? PAL ??
going OS??AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
hey hows that DVD writer you have ??
recommend it ??
where did ya pick it up from ??
i have been looking @ the Ricoh mp5125A
its a DVD+R/RW only but only $460AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
i openned up some DivX files i did last year and looked at the change Frame Rate option and it says
* No change (25.000 FPS)
then down @ change frame rate so audio and video match
it has in brackets (25.000)
and obviously these files are sync
but i know for a fact when i captured them the frame rate wasnt 25.000 fps in the stats section,
i tried VD just then and it gives round 24.7/8 capture rate
this doesnt make sense to me
To DaveQB –
I know I am Australian; I got imported stuff from the States. They're DVD's and LD's in my collection with the normal PAL versions. The NTSC DVD’s are region 1.
I don’t have a DVD burner just yet; sometime this year I’ll get one.
Regards
Chris
oho k, i thought i saw that in your PC details, my bad
Video/sound out of sync and lagging on pc
By keaze in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2012, 23:09 -
Sound out of sync in ulead video studio..
By iames85 in forum AudioReplies: 5Last Post: 24th Apr 2011, 05:10 -
DVD Video/Sound out of sync!
By bprobinson in forum Authoring (DVD)Replies: 0Last Post: 23rd Feb 2010, 16:51 -
DIVX sound and video not in sync
By DarkPhoenix77 in forum MacReplies: 2Last Post: 27th Feb 2009, 12:48 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 21:11
