Could really do with a bit of help from someone in the know.
In short, i'm not really a computer wizard, yet really do want to start copying DVD's onto SVCD/VCD. Been looking around at all-in-one software, as don't really have the time to work it with freeware.
I'm really looking for some advice as to some software that i can purchase that will do the job, with the minimum of effort.
Examples i've seen are: DVD Squeeze / DVD Wizard pro etc
Any advice would be appreciated![]()
Thanks,
Si -
if your looking for svcd creations i highly suggest dvd2svcd its great software theres only one fee... and thats for the encoder, either tmpeg or cce... i personally use tmpeg its great... just set it up one click then about 8 hours later two cd images...
good luck with your search
RyanYou win some, and you lose some, and some get rained out... -
Start hereOriginally Posted by Travelling Si
http://www.vcdhelp.com/forum/userguides/135238.php -
DVD2SVCD
You can accept the defaults and get a good rip. You can tweak the settings and get a great rip ( this generally involves 2 vs 3 vs 4 CD versions of a movie ). Does subs, multi Audio....and AC3 sound.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
If you are very new to this stuff, i would recommend EazyVCD from eazyvcd.tk. Its a very simple all in one program that makes VCD/SVCD/XVCD/XSVCD in a few clicks. If you would like to have more freedom then i would recommend DVD2SVCD as it has lots of more options.
Just want to say a big thanks to all of you for responding. I have to admit, i was a bit wary about using such a forum for such a simple questions, as i really didn't much fancy the handbags at dawn experienced by poor old 'Disover Platinum'. See the question above.
Anyway, i'm going to give DVD2SVCD a try with a TMPEG encoder. No doubt there may be a few questions in the process, but once agin thanks for the advice.
Thanks,
Si
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
