I've downloaded two ac3-files which I suddenly can't play or convert with TMPGenc. Suddenly meaning that I always could before. In TMPEGenc I'm told the audio is not supported or not recognized. When I want to play the files Mediaplayer either crashes instantly or gives me the following error message:
AppName: wmplayer.exe AppVer: 8.0.0.4487 ModName: iviaudio.ax
ModVer: 1.0.0.1 Offset: 0001190d
I have divx 3,4,5 installed and an ac3 decoder that includes iviaudio.ax
I also had the Nimo Codec package installed (V5 build8) but I uninstalled it when I downloaded another codec package called OdioDec1.23. With the Odio thing I could get the files to play but only without sound.
Now I tried to reinstall Nimo but I can't anymore because I'm getting trouble with a Winsystem.dll file. If I ignore the problem nothing at all plays.
Then I tried to install the Divx Total package which then isn't compatible with the Windows XP logo (damn XP anyway). When I install nonetheless nothing changes, I can still play every file except the ac3 ones.
Does anyone have any idea what I could do? Is there sense in converting the ac3 to mp2, or will it not change the problem?
you are in codec hell ...
if it was me i would spend the time and remove them all and make they are all unreg also .. you can use http://www.analogx.com/contents/download/audio/dxman.htm for this ..
then install powerdvd and see king johns codec guide .. .. remeber you don't need to install a ton of codecs and in most cases even a package like nemo has more than what you need .. -
Thanks! I was wondering if everything got uninstalled correctly, sometimes it didn't seem like it.
Can I find King John's codec guide here or somewhere else?
Edited to say: I do have PowerDVD but it's the same problem as in MediaPlayer
Used mkvtoolnix and need help making audio from mka to ac3 Major help pleas
By csta in forum AudioReplies: 10Last Post: 2nd Aug 2017, 10:03 -
AC3 codecs
By hawkeye48 in forum AudioReplies: 6Last Post: 1st Apr 2012, 06:17 -
Major Video Playing Problems..
By SpazRaven in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2011, 15:43 -
Have major problems with dvdauthorgui
By blue-eyed in forum Authoring (DVD)Replies: 1Last Post: 25th Apr 2008, 23:05 -
diff. btw ac3, divx, ffdshow codecs???
By geronemo in forum Video ConversionReplies: 0Last Post: 18th Nov 2007, 15:25
