IT is possible convert the file format d2v (DVD2AVI) to MPEG with Hardware encoder?
When i ripping in usual mode i use TMPEnc program that convert D2V file in MPEG file. The time for this conversion is very high. If i buy Hardware card that capture in MPEG2 with hardware encoder , it is possible use it for converting d2v file in mpeg format?
Sorry for my bad English
I doubt this could be done. Most hardware encoders take analog video / audio as input (similar to a video tape recorder).
However, to speed up the MPEG conversion, you could upgrade your PC to be as fast as you can (Pentium-4, 2+GHz, DDR memory), and/or get CCE software. This one converts DV/AVI to MPEG really fast (click on Tools on the left to learn more about it).ktnwin - PATIENCE
problem ripping BR lately..hardware? protection?
By carlos28355 in forum Blu-ray RippingReplies: 9Last Post: 27th Jun 2011, 00:17 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
What 's the best hardware and software for ripping blu-ray movies?
By HartsVideo in forum Blu-ray RippingReplies: 70Last Post: 6th Nov 2010, 16:02 -
hardware needed for ripping VHS on a mac?
By Itsmeshane in forum MacReplies: 5Last Post: 27th Apr 2008, 04:02 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22
