Hello, maybe someone has had this problem....
Ripped Chris Rock Bigger & Blacker, and did the first pass of the movie in CCE 2.5, using one pass vbr. That was fine, but I wanted to compress the file more, so I then switched to multipass VBR ala Robshot method. When I started to encode, CCE locked at frame 48. This is the only DVD out of the last 150 that I have backed up that I have had this problem with. Is there a switch that I should set in the encoding? I have encoded the file with different settings nearly 10 times, its getting old. I have also tried this on 3 different computers. Any ideas?
_fester_
Results 1 to 1 of 1
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 10:45 -
Encoding 16:9 Widescreen MKV using CCCP pack and CCE results in 4:3 MPEG 2
By octagon69 in forum Video ConversionReplies: 21Last Post: 17th Oct 2008, 20:52 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 11:10 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 15:37 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 04:46
