    Jan 2003
    Niagara Falls
    I'm half-way through a conversion and while running TMPGEnc I recieved a pop-up message. When I clicked the start button a message popped up stating " Can't load P3Package.dll". The first time I attempted this program I didn't get this message. Since then I updated my aspi info to allow VCDeasy to work. Did that have anything to do with it or may it be something else? any info would help. Thanks.
    Apr 2002
    The State of Frustration
    Do not know what caused it, but you may want to reinstall TMPGEnc.
    Hello.
    Jan 2003
    Niagara Falls
    Thanks, I wanted to aviod that but I guess I will have to. What would happen if I continued? And if I left this window open while I reloaded TMPGEnc, would I be able to continue with my project? This is frustrating work!!!
    Dec 2001
    USA
    When your reinstall make sure you have the P3Package.dll and P4Package.dll in the directory for TMPGEnc. If not you will have to download again.
    May the force be with you.
    Seaside, CA
    You have a pretty small hard drive (for video editing and/or conversion.) Is there any chance that with the Windows swap file and any temporary files TMPGenc makes (I'm not sure if it makes any) that your hard drive was close to filling up? The hard drive filling up can cause any number of errors in different programs.
  6. Far too goddamn old now EddyH's Avatar
    Jan 2003
    Soul sucking suburbia! But a different part since I last logged on.
    20Gb is perfectly usable, so long as it isn't overfilled...
    -= She sez there's ants in the carpet, dirty little monsters! =-
    Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
    Jan 2003
    Niagara Falls
    It had been a while since I had checked my resources, and it was indeed full to the brim. I havent had time to try again yet, but I hope cleaning up my hard drive helps.
  8. best buy has wd 100g's w/8mb cache for 89 bucks this week,
    after rebates
