sorry my english...
I use the normal 480x576 for SVCDs...
Now, and after i read about other format, CVD, that use 352x576, i'd like to try it...
how can i calculate the bitrate, like we see in TMPGEnc, form the wizard?
because i think, that the bitrate in CVD can be more than in SVCD...
thanks
The bitrate will always be same whatever resolution you choose, so you can calculate the same way as for SVCD. If you lower the resolution you get more "bits per pixel" and it should then be a bit better but you then lose some sharpness.
www.vcdhelp.com/calc
www.vcdhelp.com/tools#calc
How do I calculate bitrate for 320x240 .m4v?
By dave692 in forum DVD RippingReplies: 1Last Post: 5th Aug 2011, 16:31 -
How do i calculate the correct bitrate for Xvid codec?
By Ingolf in forum Newbie / General discussionsReplies: 4Last Post: 9th Jan 2009, 09:32 -
how to calculate movies sizes
By hespinoza in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2008, 10:40 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 10:51 -
calculate the size to save
By Cazz in forum EditingReplies: 7Last Post: 11th Jan 2008, 06:05
