I have an avi file which when encoded as per the vcdhelp method using tmpgenc makes a very narrow film when viewed on uk widescreen tv. I used the "keep aspect ratio" as per the guide. Is there anyway of making the image larger to fill more of the screen as at the moment its split into three. ie. top black border, film, bottom black border
Change the Source Aspect Ratio to 16:9 in advanced settings tab. Tmpeg has a preview function in the file menu,it will show you what it looks like before encodeing.
The Source Aspect Ratio for DivX is 1:1 (VGA). If you don't want any black borders, next to Video arrange method select "No margin (keep aspect ratio)". TMPGEnc will remove the black borders and your output MPEG will be Full screen. The only problem is some parts of the sides will be cut out of the output MPEG.
Hope That Helps!!! -
Is there anyway to get a full screen without losing some parts from the side?Originally Posted by puertorican138
No, but the sides shouldn't matter that much anyway.Originally Posted by neokenzo
YES, this is the correct method when converting for 16:9 widescreen tvOriginally Posted by wulf109you know it's the anti-Midas touch when all you touch goes to shit..............
there is a way to have letterbox and centre the video, but it requires a avs script and dll filter, check out the KVCD Forum, there and just either ask or browse the forum for the flter its called gripfit_preview
Video size for MP4 - Widescreen
By NoBuddy in forum Video ConversionReplies: 11Last Post: 12th Aug 2011, 22:13 -
confused about widescreen (16:9) and normal (4:3) size
By jbusser in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 22nd Mar 2010, 16:45 -
DVD wideScreen to DV - keep display size
By DavidCasillas in forum DVD RippingReplies: 1Last Post: 24th Jan 2010, 11:14 -
Whats the actual size of my video?: miniDV NTSC widescreen
By vid83 in forum Newbie / General discussionsReplies: 33Last Post: 26th Dec 2008, 21:03 -
YouTube and Adobe Premiere Pro 1.5. What size video? I shoot widescreen.
By vid83 in forum Video Streaming DownloadingReplies: 0Last Post: 17th Jun 2008, 00:32
