I am looking for the best place to get Ritek 1X-2X DVD-R for a reasonable price?
Thanks for any tips!
I get them from shop4tech.com
usually I actually spend the few extra cents and order the Primedisc which are also Riteks, but either will do. -
Thanks flaystus!Originally Posted by flaystus
Have you been satisified with shop4tech?
Have yo tried allmediaoutlet?
Is there any difference between the Ritek and Primedisc?
I checked and they seem to be identical (both share the same price, same description and same manufacturer; only the name/branding is different).
What is a Reasonable Size for a DVD File Converted to AVI or MP4?
By Novice20 in forum Video ConversionReplies: 3Last Post: 23rd Oct 2011, 22:58 -
tv player at reasonable price that can play hi bitrate xvid/avi?
By extent in forum Newbie / General discussionsReplies: 0Last Post: 25th Feb 2010, 09:42 -
upgrade video card reasonable?
By gooberguy in forum ComputerReplies: 2Last Post: 23rd Apr 2009, 12:00 -
Good DVD Recorder with internal hard drive at reasonable price
By geek2330 in forum DVD & Blu-ray RecordersReplies: 30Last Post: 1st Aug 2008, 05:15 -
1080i video capture - is there any cards at a reasonable price
By mikesbytes in forum Capturing and VCRReplies: 7Last Post: 1st Feb 2008, 15:53
