  1. Can i?
    Im Nyq, who are u?
  2. NO, they are .sup files for use in ifoedit.
    what you need is .son files for maestro.
    try using subrip to get them.
    thingimijig.
  3. i am using maestro and subrip, but i get a really strange and annoying error, i import the subrip file to maestro, but it doesnt get rigth, i just get 24 subs, when there should be over 500 of em, and they aint in the rigth place either. I checked the *.son file, and it lookes rigth, and all the bmp files lookes rigth too. But if i take show all subs in maestro i can see that its totaly screwed.
    Im Nyq, who are u?
  4. i had that once.
    now i dont know if it will sort it out but it did for me but i only had about 30 subs.
    what i did was start again with maestro, add the video then ac3 then i added the chapters with chapterxtractor which i didnt do before and when i added the subs it accepted them all.
    thingimijig.
  5. that didnt help, but i found the problem, i had to change the time under wall clock in maestro to 00:00:00:00 =)
    Im Nyq, who are u?
