Hi guys
I have a bit of a problem(newbie). I convert DIVX to MPEG and use ULEAD to create chapter but i get this error:
some chapter entry frame numbers exceed the total frames
Is there any settings I need to change?
I use TMpeg and convert it on NTSC DVD, CBR 6000kps
is this correct?
Any advice is welcome thnx!
0wn4g3
Trial or registered version?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 04:48 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 03:20 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
